Chicken Head Knob Dimensions?
Fender Amp Discussion
Roaddogma
Post by Roaddogma »
I am restoring an original 1959 4x10 Bassman (5F6-A). The amplifier does not have any control knobs, so they need to be replaced. I bought some off eBay that measure 1.25", but they look a little small in the bag. Can anyone confirm the correct length of the chicken head from the pointer-tip to tail?
Thanks.
Re: Chicken Head Knob Dimensions?
They should look like this:
31.7mm beak-to-butt.
xtian wrote: Thu Nov 30, 2023 10:49 pm31.7mm beak-to-butt.
That's 1.25" American, pretty common size. I'd get high quality new knobs with brass inserts.
I am an American sciencemonkey, and I try to use metric whenever possible because...Imperial :roll:
https://www.tubesandmore.com/products/k ... ass-insert
Reeltarded
Post by Reeltarded »
I'd rather use cosmological measurements.
ViperDoc
Post by ViperDoc »
Reeltarded wrote: Fri Dec 01, 2023 1:22 am I'd rather use cosmological measurements.
AGREED. The chicken knobs that are 1.0272197e-18 parsecs in length will do quite nicely. If they're not on backorder, of course.
Just plug it in, man.
Reeltarded
I was thinking Plank.
I cheated with a calculator.
1.964666934E+33
ViperDoc
Post by ViperDoc »
Right. So did I. That's a nice range. Anything between those two oughta do it.
Roaddogma
Post by Roaddogma »
Right! Okay. Thanks for the replies. I think I got it now.
These are what I got. Measuring 31.6mm. I'm just going to roll with those, hoping they are within tolerance....
Roaddogma
Post by Roaddogma »
Also, This is what else I'm dealing with....
I'm glad for the original board, but the amp is a basket case. The cab is also covered in ratty old black tolex... At least it still has the original iron, so someone needs to give it some love.
