EVM12 cab alternatives..
Aurora
Post by Aurora »
I managed to get hold of an EVM12 locally, for project I'm working on... have anyone tried other cabs than the traditional reflex cab that's been around for a while... Open back, partially closed... etc ??
Colossal
Re: EVM12 cab alternatives..
Post by Colossal »
Aurora wrote: Tue Feb 15, 2022 8:47 pm I managed to get hold of an EVM12 locally, for project I'm working on... have anyone tried other cabs than the traditional reflex cab that's been around for a while... Open back, partially closed... etc ??
I've had excellent results with variants on the "widebody" 1x12 Two Rock style cabinet with a (partially) open back.
sluckey
Post by sluckey »
I put one in an old TV cart...
http://sluckeyamps.com/TVcart/TVcart.htm
jabguit
Post by jabguit »
Colossal wrote: Tue Feb 15, 2022 9:42 pm
I've had the exact opposite. Swapped the Eminence in a TR String Driver 1x12 cab with an EV to use with my old K&M LTD amp and it was choked sounding. Pulled the EV and put in a Celestion 12H30 - huge difference. Sounded like a blanket was lifted off the cabinet. The 1x12 SD cab was the only one that the EV didn't like.
cheers,
Jack Briggs
Briggs Guitars
Geeze
Post by Geeze »
I built 3 TL806 cabs - one pine [that's what the customer spec'd] and two out of African Mahogany and Canary wood. They sound good - but - I built a copy of the Zilla Fatbaby OS 1x12 and it [non ported] has more low girth than the TL806's. I was impressed enough that I built a second one.
Other benefit the small box 1987 & a Satellite Cuda heads look much better on them as well.
10thTx
Post by 10thTx »
Thanks remarkably beautiful! Thanks for sharing the photo. Always enjoy seeing your woodworking.
With respect, 10thtx
Phil_S
Post by Phil_S »
A stellar example of work done by Russ. As usual, he is too modest. A Google search will show you that he documented this cabinet build on another forum. (He may have done it at TAG, too. I didn't look.)
telentubes
Post by telentubes »
Cabs by Sluckey and Geeze are awesome!
